Revit - lighting analysys error
3 REPLIES 3
kanoferreira
345 Views, 3 Replies
Hello guys, anyone having this problem?
After i upgraded the Analysis Plugin, This happened.
I tried to unninstall and reinstall, not worked.
Anyone knows the fix?
thanks.
3 REPLIES 3
hi
After unninstall program, go to path:
C:\ProgramData\Autodesk\Revit\Addins\20XX
and Software plug-ins manually delete it. Perhaps the problem is resolved.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
in reply to: kanoferreira
i have the same problem.
in my case everything still worked fine when this thread was posted.
now revit told me i had to get a newer version of solar analysis. after i installed the new version, i got the same error.
i tried to delete the add in files and the files described here which only brought me back to the old error that told me to get a newer version.
obviously it has nothing to do with the version you download since your problem happened last year...
did you get the problem solved 5123123486 ?
edit:
i deleted the addin files as described here and deleted (copied elsewhere) the files from programs/autodesk/revit2015/addins/2015
and did another installation of the .exe that came with the add in
