Hello, I'm trying to make a pendant light fixture family in Revit which can have a parametric length. I created a ceiling offset parameter but everytime I change the length, the size of the base alsochanges. How can I only change the length of the fixture without making changes to the base.
Thank you in advance!
Solved by martijn_pater. Go to Solution.
Add dimensions & lock those and/or add parameters to them. Also lock the geometry to your refplanes, else your pendant light falls off its cord...
