Revit Library issue
Revit Library issue
Revit Library issue
Hello!
When I installed Revit, the library didn't install. I don't have access to making new files in the "architecture" layout. If someone can please help me figure this out or how to get the library, that woudl be great!!
Thanks!
sureshchotrani
  1. In the Control Panel, uninstall Autodesk Revit Content Libraries 2015.
User-added image
  1. Select Add/Remove Features.
User-added image
  1. Select the content to install.
User-added image
  1. Click Next.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Hi there! Thank you! I am currently doing this right now. Hopefully it works! But It has been in the "updating" stage for at least 3 hours. It hasn't moved. Is this normal?
sureshchotrani
Yes, this will take time. It downloads the content from Autodesk website. Be patient don't cancle installation.
I cannot find my library (temp) location revit-2016 please help me
but libraies are already installed
sureshchotrani
Wellcome to the community:)
Kindly check here & follow the instruction.
