Revit Levels not showing, but items are still linked?
NathanMorassut
NathanMorassut
I have a project that was created off an architects revit model, but I am not sure what happened to my levels. The architect on our project changed the level 3 height, but I cannot find anywhere to move my level 3 height.  When I click on a model element there are 4 options of levels to link it to, but can't find anywhere to change that level height
Just wondering if there is a work around instead of having to create a new level and move everything over to that new level.
lumbera_darwin
Hi @NathanMorassut ,
You can try creating Level Schedules in "Schedules/Quantities".
Hope this helps.
Dar
kostask_oionei
Can you see the levels in another view? Check in a 3d view with zoom to fit and unchecked the  crop view.
Turn off any scope box also.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
craigjonnson
This can happen when the gridlines have been adjusted within a plan view.
  1. Either create a fresh 3D view with your levels switched on. Select a level, if visible. Right-Click and pick the option to select all in project. Right click again and pick "Reset to Crop".
  2. If you cannot see any levels in 3D. Draw a dummy level in your section and follow the above suggestion.
NathanMorassut
Thanks, The levels were way off in the distance in 3D
