revit label calculated value text
tehila3GL9K
tehila3GL9K
I have parameter "current revision" that look like this- "for aproval-1" or "work in progress-12"
I want to use the same parameter for Design Phase BUT I need that label to be without the "-12"
Do you all know if I can use opperation like LEFT in excel for text in the calculated value?
or any ideas that can delete the hyphen and the number?
A Calculated Parameter in a Schedule?  A Calculated Value Label in a Tag? What does the formula read?  What is it evaluating?
No.  You would need to use Dynamo to extract a partial value of a string and write it to another parameter.
