Revit keeps opening old file version
diego.veloso.98
diego.veloso.98
Hello there, I'm having some trouble recently with my Revit/Google drive desktop. I will work at a project at home, save It, and then, at work, sometimes It seems that Revit opens an old version from the file, I'm not sure why, and the later I notice that, more work is wasted, since I've been working on an old version and all that changes cant be "merged" with the old ones. So when that happens I lose the work currently done and open the latest Revit recovery file and start again working on It. Does anyone ever had that issue? I'm not sure if It's an Revit or google drive, but I bet It has to do with Revit, since in my google drive I can file the Revit recovery file.
Thanks a lot !!!!
Alfredo_Medina
How much time is spent in all that process of using Google Drive and how much is that time worth? If you want to work at home and at the office on the same file, have you considered BIM 360?
RSomppi
Doubt it. Utilizing Google for this is not recommended.
