Revit keeps crashing
8 REPLIES 8
Message 1 of 9
micah
405 Views, 8 Replies
We are working on a larger Revit project (hotel remodel) and we have inserted a CADMapper DXF CAD mapper file (to provide context of the surrounding area like adjacent building massing, flatwork, topography, etc.). Revit crashes every time we insert a family such as plantings in the site. This only started after we had inserted the CADMapper site data. Revit is also not creating a backup file. As a result, we are unable to recover the work. We get this error message: "A software problem has caused  Revit to close unexpectedly..."
CAD mapper has been used in the past with another project without any problems.
Please advise of any possible solutions. Thank you in advance for any help.
8 REPLIES 8
Message 2 of 9
in reply to: micah
Hard to help you troubleshoot based on the limited info you've provided.
Message 3 of 9
micah
in reply to: barthbradley
What more can we provide? We are here to help people smarter than us, help us.
Here is a link to the file.
21-015 - 601 Cypress St, PB - Inn at the Pier Remodel - Pacifica Hotels.rvt
Password: r4VgtcgiMWoL
https://msacloud.egnyte.com/dl/Ig8XPzRVN4
CADMapper file:
cadmapper-pismo-beach-california-us.dxf
https://msacloud.egnyte.com/dl/P0vYpMSQgp
Password:y9BjNu56MLqK
Message 4 of 9
in reply to: micah
You're kidding.  How about we start off with the Version/Build of Revit and the Operating System?
Message 5 of 9
in reply to: micah
The DXF doesn't cause any issues here.  Must be your Revit model itself.
The Revit file (upgraded to 2022) doesn't crash here either.
A personal note: if your CAD files are for reference only then link each in a specific plan/rcp view with the box Current view only ticked so that they don't make a mess in other views including 3d views.
Also, go though Warnings and fix as many as you can.
Message 6 of 9
micah
Revit 2021.1.6.
Windows 10 Pro.
Message 7 of 9
micah
in reply to: ToanDN
Thank you @ToanDN . The dxf file was removed prior to uploading to the post because we felt it was creating the crash and had to move forward in our work. Did you place the the dxf yourself?
Thank you for the note on the warnings. We will look into them.
Micah
Message 8 of 9
in reply to: micah
Micah
Yes.
If you have any 3rd party add INS then disable them.
Message 9 of 9
micah
in reply to: ToanDN
Hello @ToanDN ,
We are trying to resolve the warnings as per your suggestion. The first 19 warnings are "Could not create Wall Sweep. Two wall sweeps are overlapping." How can we resolve these warnings and better achieve the exterior finishes we are modeling?
Password: tDw6tgtHArrs
https://msacloud.egnyte.com/dl/EWUOpoYeHI
