@VAdamskyi wrote:
I like how every question about revit only using only 30% is dodged and the customer is blamed for overloading precious revit.
I have similar problem where I have ssd, 128 ram (currently most powerful designing laptop from Dell)
Yet, revit is lagging and only using
I've complained to IT about it and they say that its not the computer but the revit issue.
He mentioned poor coding and poor optimization.
Never had an issue with other apps like: cad, solid works, inventor.
Only happens with revit.
Fastest laptop from Dell is like saying you got the fastest 3-legged horse. What exact specs? And what are the temps? They overheat, and then the CPU/GPU throttles.
Open task manager and show all logical processors. You most likely see a single core (single thread) doing all the work on many Revit tasks. Out of 8 cores with HT a single core working 100% will only contribute to 6% of total CPU performance.
And windows task manager doesn't show correct clock speed. You need to install Ryzen Master (AMD) or XTU (Intel) to see what each core is doing. Some cores will run at 5GHz, some will be sleeping. And monitor temperatures, especially on a laptop.
Yes, Revit has some poor coding and is poor on multi-threading. But a CPU with high single-core speed still will leverage good hardware. and obviously there is also modeling efficiency. I recently got a new PC and it really got a few fold better. There isn't a laptop that can perform very well.
And what version of Revit are you using? Since this is an old thread, i just say that modern Revit versions allegedly use more cores better than older versions (at least to every year's release notes....)
Some forum member made a benchmark for Revit and you can see that modern hardware really helps.
https://goto.archi/best-laptop-cpu-for-revit
Revit Version: R2026.5
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
