Revit interface properties pallet
Message 1 of 9
i new with Revit software, i hide properties pallet by mistake because when i click on it it don't open Type properties pallet, why?
Replies (8)
Message 2 of 9
constantin.stroescu
go to View > User Interface>click on the small triangle from bottom right to open menu and check Properties
Constantin Stroescu
Message 3 of 9
constantin.stroescu
Constantin Stroescu
Message 4 of 9
You can also select on any element and activate Properties from the Right-Click Menu.
Message 5 of 9
mauricio_mssf
Hi @Anonymous
Is Just type de Shortcut key PP.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 6 of 9
lucdoucet_msdl
The combination CTRL key + 1 will also open/close the object properties window.
-luc
Message 7 of 9
Mohamed-Nassar
Hello, Check if you have double screen it doesn't open there, so for it hide go to View then Window panel > User interface select Properties.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 8 of 9
Thanks for all it's the same way thanks for your interest
Message 9 of 9
Hi, I have checked the properties box in the user interface but it still doesn't appear on my page. Any ideas??
