REVIT INSTALLATION FAIL ON WINDOWS 10 HOME
chiragwaghela01
Observer Observer
chiragwaghela01
Observer
Observer
what does this mean to the rest of us?
provide more info if you want any help
Matt__W
What sort of error message are you getting? 1603? 1308? Missing DLLs?
Can you share a copy of the log files?
LOCATION OF THE LOG FILES GENERATED BY THE INSTALLATION OF AN AUTODESK PRODUCT
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Location-of-the-log-file...
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
chiragwaghela01
Observer
Observer
Respected sir,
As Mentioned above revit installation fails every
time 8 try in this windows 10 home operating system.
I've checked system requirements, windows home version is not mentioned
there.
Also I'd installed revit 2016 in last August and uninstalled it.
Considering that time i should be able to install it again in the same pc.
Ive tried installing version 2014,2016,2017,2018...but same problem
everytime. Product couldn't install.
##- Please type your reply above this line -#
chiragwaghela01
Observer
Observer
Respected sir,
Sorry i couldn't keep track of log files. But the
product installation fails without occurring any error you mentioned.
there.
Matt__W
There could be a number of reasons why it's failing, and without an error code or the installation logs it's difficult to say for certain what could be causing it to fail. But a good place to start is to clear out your %TEMP% files and empty the recycle bin aftewards.
HOW TO DELETE TEMPORARY FILES IN WINDOWS
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-delete-temporary-...
Matt Wunch
Twitter | LinkedIn
