Revit imperial
Revit imperial
Revit imperial
How to Switch Revit from metric to imperial and from imperial to metric ? Like I want to switch Revit completely( like autoCAD or Civil 3D we have tow versions, imperial and metric)
Ilic.Andrej
use shortcut: un
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
_Vijay
You can change units the settings(UN). But recommended using respected templates for a better experience.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Mohamed-Nassar
CHANGE UNITS OF REVIT AND CHECK FAMILY UNITS ALSO
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Can you explain me more ?
Can you explain me more ??
Ilic.Andrej
I am sorry to interfere in your conversation. In case people didn't tell you already, you should press "un" to bring up the dialog box that you need. I just wanted to make sure we didn't miss anything. Again, sorry for interfering.
Andrej Ilić
MSc Arch
