When Revit is installed a special family template folder is created in C:\ProgramData\Autodesk\RAC 2014\Family Templates\English_I (location varies slightly by Language pack). RPC Family.rft must be present inside this folder or Drag & Drop cannot be performed. The problem occurs when non-default install locations are used. Inside Revit the location of the Revit Family File path is shown by clicking on Revit–>Options–>File Locations.
This can be resolved by downloading the following file and putting it into the directory specified in “Default path for family templates file”
Download the necessary file from attach.
It will need to be unzipped for Revit to recognize it. Once in place simply restart Revit and Drag & Drop will work.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
