Revit hatch lineweight
tpreisler
tpreisler
Hi, where can i set my wall hatch to be a heavier lineweight? (see attachment)
material cut pattern
oops.
@barthbradley
Are you sure?
@tpreisler
I think only Filled regions can have different fill pattern lineweights.  Material cut pattern lineweight is always 1.  You can change lineweight 1 to thicker globally but it will affect everything with that lineweight.
tpreisler
Thanks, I see my hatch only in fine how can i see it in coarse as well?
is it a wall? Set it in under the wall properties (Course Fill Pattern/Color)
@ToanDN wrote:
@barthbradley
Are you sure?
@tpreisler
Exactly....That's why no category should be set to 1
honewell
and what if you want to change 2 pattern to 2 line weights?
