MODIFY PANEL, tools for join geometry and connect roofs has disappeared.
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
KKProssick
2333 Aufrufe, 12 Antworten
For some reason I have lost the tool buttons in the MODIFY PANEL to join geometry and connect roofs.
Any clue on how to bring them back?
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: KKProssick
Cycle through different Ribbon appearances?  Restart Revit?  Update to 2018.2?
Nachricht 3 von 13
als Antwort auf: ToanDN
Actually, what you're missing is the Geometry tab.
Nachricht 4 von 13
KKProssick
It was there yesterday. :leicht_lächelndes_Gesicht:
Is there an easy way to get it back?
I have cycled through the panels and restarted Revit , as well as restarting the computer.
Nachricht 5 von 13
@loboarch: Didn't you post a solution about this a while back?
Nachricht 6 von 13
There was a $20 bill in my wallet yesterday as well.  I know the feeling :zwinkerndes_Gesicht:
I would run a repair installation, or better yet, run 2018.2 update.
Nachricht 7 von 13
loboarch
als Antwort auf: barthbradley
Not that I recall???  I am not sure what would cause that?  I would try and reboot, repair, and then re-install of Revit. In that order.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 8 von 13
KKProssick
Currently running the .2 update
Nachricht 9 von 13
KKProssick
 Installed the update and it sort of fixed the problem.
The Geometry Tab now appeared as a 'FLOATING TAB' . I did not even know they could do that. Interesting.
I can at least put it back now.
Nachricht 10 von 13
Ha! Neither did I. Something's batty.
@Viveka_CD
...Hey! You can dock and undock 'em! Cool! 10 years and still learning!
Nachricht 11 von 13
KKProssick
@Viveka_CD
About time. :leicht_lächelndes_Gesicht:
Yeah, been using Revit 11 years and I still learn new things with it.
Nachricht 12 von 13
How did it not show in your original screenshot?  Off screen?
Nachricht 13 von 13
KKProssick
Possible.
It appeared after I did the .2 upgrade.
