Revit Gas Station / Petrol Station
7 REPLIES 7
Message 1 of 8
Pat_Slattery
12650 Views, 7 Replies
I am looking to get hold of the Autodesk revit petrol station .rvt file which used to appear in earlier versions of Revit. An image of one of the sheets is
If anyone has this file I would appreciate it if you could send me the file of a link.
Pat
7 REPLIES 7
Message 2 of 8
in reply to: Pat_Slattery
Hi...
I from Brazil...
I need the families dor Gas Station....
You Help me ???
Thanks !!!!
Message 3 of 8
5 years after your post, I have the exact same request. Did you find it from somewhere eventually?
Message 4 of 8
Did anyone get the model? I could use it too
Message 5 of 8
You won't find it unless you have the original Revit installation disks from before Revit was purchased by Autodesk.
So to call it the Autodesk Gas Station is incorrect...it is the Revit Technology Corporation Gas Station.
Message 6 of 8
h i need file plz
Message 7 of 8
RobDraw
You NEED it? What kind of requirement are you dealing with that you need something that is so old and not readily available?
Rob
Message 8 of 8
50034580
can you send me the download thanks like
