I use Revit in a virtual Windows machine on my mac. I'm thinking of replacing my MacBook with a new generation one, but because Apple has created their own M1 chips, its not possible to run virtual windows anymore. It's a pity, these new chips seem very powerful and efficient.
When is Autodesk going to port Revit to the Mac platform? If this does not happen anytime soon, I'm afraid I and many other architects will have to find another BIM-solution
Solved by jeremy_tammik. Go to Solution.
Solved by RobDraw. Go to Solution.
It appears you are very statically happy with what the Market place offers at the moment. Railroaded choices. Development / change makes a better world. As my original question only raised speculation on any development option for alternatives, i think the overstatement on what is current in the marketplace is only relevant to those who resist change.
Será, our lo que muestran las nuevas M1 es que pueden mover gráficos en 3d, mira los juegos que puede correr en este M1, parece que si mueve gráficos 3D
Biased much? The platform zealots in online forums always see things only from their perspective.
The fact is that the Windows operating system, perhaps because it is so widely used, is the primary target for thieves, hackers and malcontents. It is rare, but instances exist, where Mac OS systems get hacked.
How many software attack vectors exist in the legacy closed-source wad of gum and shoelaces that is the Win10 OS?
The heart of Mac OS (itself bundled with much proprietary Apple code) is an open-source BSD plus goodies aka Darwin. Less hackable because its source code can be scrutinized by white hats who find bugs, report them, and get rewarded. Microsoft Windows OS will die someday, falling to Linux and other open-source OSes.
On the matter of OS support from AutoDesk, I have worked with engineering teams at some of the top application software companies in the world in my past. From that experience, I would speculate that it is almost always a sign of sloppy coding standards, needless adoption of proprietary OS-bound APIs, and hacky guts that make a software app hard to port across operating systems.
thank you sir, for your very clear explaination of the problem. but i m unlucky sir, i m a revit user and i thought it would run via parallels and rosetta but it is not running, it is just closing after installing. waste of money but now cant afford another laptop again
It's one thing to embrace new technology. It's a totally different thing to jump the gun hoping it will work sometime in the future.
Good luck!
Just now tried in installing revit in parallels after several trails last month, and i received a mac os update last week so tried installing it again today. now revit is working in parallels in m1 macbook pro. hope it improves still, still small frame drops while rotating the 3d image in realistic view, but something is working is happy to me, because it didnt even open when i have installed last time. finally feeling happy that i didnt waste my money on m1 macbook and parallels.🙏🏻🙏🏻
Revit works well with Intel based Macs and Parallels but does not work even with the new version of Parallels for the Mac M1. Is Autodesk addressing coordination with Parallels? Rumor has it that AutoCAD does work with the newest Parallels for the M1 Macs, why not Revit?
They are entirely different platforms. Having one work does not mean the other will.
You won't get that answer here. This is a user help forum. Users helping users.
No doubt some of you will have stumbled across this by now, but people on the Parallels forum are reporting Revit now works with latest versions of Parallels, MacOS and Windows on ARM release. Would be great to see some more confirmations on here!
https://forum.parallels.com/threads/autodesk-revit-does-not-work.353163/#post-888581
It looks like there is a solution to run Revit on the M1 chip. It's still damp, but it's possible.
youtube link
For all those seeking a step-by-step instructional... I have no M1 Mac to illustrate on. Buying one is in my plans before EOY'21.
Apparently there is a combination of steps which require being a Windows Insider allowing one to download either the latest build of Win10ARM for x64 code emulation, but older versions of Revit (pre 2020) seem to have greater success rates.
I've anecdotally heard that the insider build go Win11ARM is even more compatible.
The second linked video apparently is a successful install.
