Revit family view range
Message 1 of 21
Hi, i have simple family of cube 300 cm height(30×30)
At 260 heught i cutted half
I have tried to change the view range if the family (between 100 and 200) so i will see at ref.plane 30×30 full squres(whithout the piece cutted)
But its not working at all. View range insude family is ignored
Can someone help please asap? Thanks alot!
Replies (20)
Message 2 of 21
Toggle your Preview Visibility to ON.
Message 3 of 21
Where is this visibilty?
Message 4 of 21
On the View Control Bar (bottom near eyeglasses).
Message 5 of 21
Which category does that family belong to?
Message 6 of 21
hi
family is attached
visibility is disabled
when I created family I have chose furniture template
I want the family to show only 30*30 empty square in view range(without the hidden lines or above lines as solid
I tried to do that by view range but it doesn't seems to have any effect
thank you
Message 7 of 21
Change the Family to a cutable category, like Generic Model.
Message 8 of 21
How to change to cuttable?(the olan/RCP is cheked already
Message 9 of 21
Try the revised family.  View range in family only has effect on certain categories such as Windows.
Message 10 of 21
 should i rebuild all families again ?
Message 11 of 21
This is great! How to revised the family please? Should i rebuild revised family again?
Message 12 of 21
planner_matlabi
Don't Need rebuild all families again
Select Family Category and Parameter and change Furniture to Generic Model
BUT
The best , Change Visual Style Wireframe to Hidden Line after Load Family In projectUntitled.jpgUntitled1.jpg
Message 13 of 21
Actualy i was wrong. This way i will hide the hidden lines. But what if i want the ref.plane to show specific view range?
Message 14 of 21
I was wrong, the goal is to fits project view range cut plan
Message 15 of 21
planner_matlabi
View Rang in Level Properties and Change Cut Plan Value BUT It has an impact on everything in Project
i Don't think , Don't Way for Changing for one Elements View Rang
Message 16 of 21
Let me explain the problem:
I insert family to the project
But in project i see the family cut plane with all hidden line top and bottom
(Same as inside)
Thas not fits the level cut plane
In the project i want to see spesific view range of the family wich is not showing ...
Message 17 of 21
planner_matlabi
Please Send Movie your proplem
Message 18 of 21
In project 3d as you can see there are 4 squres 30*30 each.
But in project level view you see alot of solid lines same as in family...
I want that level will have also 4 squres 30*30 as in reality 3d
Thanks alot
Message 19 of 21
Try this revised family.  Why do you need 4 different sub-families when you can use one?
Screenshot shows how they display in Project.
Message 20 of 21
Thank you very much
So if i understand correctly:
View range in family aplyied to generic models?
