Revit Family Not Visible in Plan View but is in 3D View - Revit 2019
jasmin_dooley
Message 1 of 14
jasmin_dooley
So I made a basic 3D family using the electrical family template, but when I try to place it in my model, I get the following yellow warning message:
"None of the created elements are visible in Floor Plan: 00_Ground Level View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
This family does place, but it's only visible in 3D views of the room and not the plan layout (which is where I need to see it most importantly).
I have also attached the family and a couple of screenshots of the plan view and 3D view of the family.
Jasmin Dooley
Technical Trainee
For Ingleton Wood LLP
Accepted solutions (4)
Replies (13)
Message 2 of 14
dferreira-blackwell
i would ask you to check visibility settings, and also some families only visible if cut plane is above them or cuting through them, try to change your cut plane settings.
Message 3 of 14
ennujozlagam
Check in properties if there is view template assigned set to none. Thanks
Message 4 of 14
It's your View Range - set the cut plane above the object.
Message 5 of 14
dferreira-blackwell
I just checked your family put the cut plane of floor plan above the equipment elevation, it will show up in plan thank you.
Message 6 of 14
jasmin_dooley
Ahh thank you for figuring it out!
How do I change the cut plane in the family?
Jasmin Dooley
Technical Trainee
Message 7 of 14
You change it in the plan view, Under 'View Range'.
Message 8 of 14
dferreira-blackwell
not in the family.. in your floor plan-->properties-->extents-->view range-->cut plane, set it above the top elevation of the equipment.
Message 9 of 14
jasmin_dooley
I need to keep my cut plane at 1000 though because then it cuts through all my windows and other families I have in my model like the elec meter box, otherwise, it won't cut through everything else. Is there no way of showing it even if it's outside the cut plane?
Jasmin Dooley
Technical Trainee
Message 10 of 14
Then create a plan region (View, Plan Views, Plan region) and adjust the height for only that part of the plan.
Message 11 of 14
jasmin_dooley
Omg I had no idea we could do that! That's blown my mind.
How do I do that?
Jasmin Dooley
Technical Trainee
Message 12 of 14
dferreira-blackwell
VIEW-->PLAN VIEWS--> PLAN REGION
Create a sqaure around your box, finish. select that region change cut plane.
Message 13 of 14
Go to Ribbon - View, Plan Views, Plan Region and draw a rectangle around your family.  Adjust the height of the region to about 2000mm.
Message 14 of 14
jasmin_dooley
Omg that's awesome! Thank you so much! This is awesome, I can't believe I didn't know about this before!
Jasmin Dooley
Technical Trainee
