Revit Family_ Height Constraints not working on loaded Family.
I have created 3 Revit Furniture Families. A drawer, cupboard swing door and a cupboard carcass. Ideally i have loaded in the door and draws into the carcass so the the drawer will tag as DRS and the cupboard as CB side by side.
I have attached the three revit families for you to look at to see where im going wrong.
https://www.dropbox.com/s/qdte8wj49njqvu4/BI_InteriorFurniture_DoubleDrawers.zip?dl=0
Thank you,
M
Set the door and drawer familes to Shared and you can tag them independently in your project.
RDAOU
@mitchellabellnepp
You need to resort the reference planes and identify those planes which are reference (Top/Bottom/Left/Right/Center) and the others which are just guides set to "Not a Reference"
The main faulty step in your family is the bottom reference plane in the 2 nested families...it was set to "Not a Reference" which results in losing the shape handle when nested and subsequently prevents the nested components from resizing.
  •  EITHER (recommended) set the bottom plane as a reference >> nest the family >> lock the Shape Handel to the bottom plane of the cupboard
  • OR (alternative) leave as is and associate the Height of the Drawers/Swing Panel to a parameter in the host family
RDAOU
Screencast from earlier reply which got Deleted
