Revit family for install
Aliay045
Aliay045
Hi, I looking to have Revit families, for example, Brick veneer 250 timber wall, but my Revit 2020 has few material families but not this Group. have some link to install or download this Revit family. Thanks
I tried to find the Revit family for install but your web doesn't have the right answer and customer service not good !!?
Accepted solutions (3)
syman2000
You want to search manufacturer content by search online. Bimobject is a good place to start. https://www.bimobject.com/en-us/product
You are talking about two different things here; Walls and Materials. Materials are not Families and Walls are not loadable Families.  Walls are System Families.  So, what exactly are you talking about?
Aliay045
 I looking to have Revit families, for example, Brick veneer 250 timber wall and ...
Then create one. Are you familiar with how to create a compound-layered wall in Revit?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/creat...
compound-walls-revit.html
Here's a ton more info on the subject. Drill down into the links.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
syman2000
You can take an existing wall from the template. This one is from 2019 Architectural Template and it contain Generic Brick 90mm
Then Duplicate the wall type and name it 250mm
Go to edit the wall thickness
Here you modify the wall thickness to 250mm. Press OK to save.
You can make any wall assembly. If you want sample wall, you can check out USG - https://www.usg.com/content/usgcom/en.html
Type a product name
