Revit families
Revit families
Revit families
Hello , can i load revit 2014 families to latest revit 2018 ?
ennujozlagam
yes you can. but do remember to backup your families in lower version Revit 2014 in case you may need it in the future. thanks
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! Smiley Happy
When you load families into a project, the Revit family library is accessed by default. See HERE for more information.
Once you load a family into a project, it is saved with that project. See HERE to Load and Save Families
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Thank you.
kadmonkee
as @ennujozlagam suggested make a backup copy of your families to be upgraded into Revit 2018.
I would open (the backup copies) them in Revit 2018 prior to bringing them into my model , simply to confirm they are still functioning as expected.
you may get varying results when upgrading 4 versions at once.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
