Revit Extensions for Revit 2019
Message 1 of 8
Replies (7)
Message 2 of 8
DarrenP
are you trying to install on Windows 10 32 bit?
if so you need to be on 64 bit
DarrenP
Message 3 of 8
First off....Revit Extensions for Revit 2019 doesn't exist...
Second...what OS are you running?  If it is 32bit...you are out of luck.  Revit 2019 is 64 bit only.
Message 4 of 8
windows 10,64 bit
Message 5 of 8
Message 6 of 8
version    10.0.10240 build 10240
Message 7 of 8
So you don't bother looking to see what version you have?  I Googled it for you....that is the first release of Windows 10..
You need to start updating your OS before installing.  Recommend updating until you cannot update anymore.
Message 8 of 8
Thank you friend, I installed it as per your instruction.
