Revit export to autocad
mbiAK7WZ
mbiAK7WZ
Hello
i am exporting some revit files to autocad and i need the elevation height from revit so i kan place elevations points on the drawings in the autocad file but i cant get it to work
i use shared coordinates and all that but cant get it to work
PrathapSekar
Please furnish more detail to understand the problem you are facing.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
mbiAK7WZ
i was a little to fast when i was writing the message my bad, but it should be better now
curtisridenour
Can you share your model? Are you exporting from a 3D view?
Export a 3D view.
mbiAK7WZ
no i didnt use 3d view, but it seems to be working when i do, thanks
