Revit export issue
Revit export issue
Revit export issue
I am working with Revit BDS 2016 and with the new rendering engine (Autodesk Raytracer) I have noticed that my PNG exports now have the backgrounds included. When I use the Nvidia Mental Ray engine, it takes a little longer to render but I am able to export to a PNG with no problem..
Is this a known issue or is this the way it is meant to work? Are there any solutions for exporting PNGs without backgrounds when using the Raytracer engine?
BK
john.vellek
Hi @Anonymous
Check this AKN article regarding setting the background to be transparent. As long as the image type is set to TIFF or PNG it should work as they retain Alpha Channel settings.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi kruegebm
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
