Revit Expert needed
Revit Expert needed
kapitalaudio1234
Revit Expert needed
kapitalaudio1234
hello community ,
iam looking for a revit expert to give some tipps in shared coordinates, ifc export and modelling.it will be about 3-4 paid sessions. what will be required is how to deal with different scenarios regarding those points. further details will be given. if you are interested please send me a message
jose_Miquelao
You’re basically asking: “Can we handle this kind of thing with Inner AI instead of hiring a Revit consultant for a few sessions?” Short answer: for the topics you listed, yes, we can go pretty far.
Here’s how I’d structure it with you:
  1. Shared Coordinates (ACC / multiple buildings / phases)
    • Different scenarios:
      • One site + many typical buildings (your repeated blocks of buildings).
      • Existing vs new construction with survey files.
      • When to use “Acquire” vs “Publish Coordinates” vs manual “Specify Coordinates at Point”.
    • We can set up:
      • A repeatable step‑by‑step workflow for each scenario.
      • Checklists to avoid the classic traps (rotating the wrong thing, broken links, mismatched origins).
      • A “recovery” procedure when someone messes coordinates in a cloud model.
  2. IFC Export (for coordination, quantity takeoff, or delivery)
    • Topics we can cover:
      • Clean export setups (which IFC schema, property sets, and what to turn off).
      • Mapping Revit parameters (including phases, classifications, fire ratings, etc.) into IFC properties.
      • Handling multi‑building projects (one big IFC vs several, how to split by discipline).
      • Typical issues: missing elements, wrong locations, phases not exporting as you expect (like your infill walls case).
  3. Modelling workflows / best practices
    • Depending on your discipline (architecture, structure, MEP), we can:
      • Define modeling standards (levels, grids, model groups vs links, typical details).
      • Create templates for repeated buildings across a site (the “typical building” problem).
      • Discuss performance and model size control in multi‑building projects on ACC.
mhiserZFHXS
If they had interest in using AI to teach them they would probably ask AI and not a forum with people who actually use Revit... Come on man.
