Revit Error: Cannot make type: Curtain-Wall- Double Storefront
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Adding mutton's to a storefront. Adding curtain grids, but finding it hard to evenly space and when placing it above a door the door is split and a error message is received. See attached images.
IMAGE 1: Shows result of placing curtain grid for the horizontal mutton (the mutton will be changed to 1" sq, but for some reason when placing the grid it automatically creates the 2.5x5 mullion?) Note how the temp dimensions from bottom up are center, center, out side face. I know how to snap temp dimensions to different points, but these will not snap to where I want to get it centered so I have to do some math and a lot slower.
IMAGE 2: Shows the vertical grid added for the mutton. Notice the door being split below and the error message, and again any temp dims will not snap to proper points to allow for quick even placement.
IMAGE 3: Shows mutton's placed above the door. I just deleted the door and added it back when finished, but notice how the mutton's are single lines. The mutton's are double lines when changing to wireframe and if I change the mutton's to any other mullion type they show up fine.
IMAGE 4: Show the mutton's as I want them to look, but as I said getting them center is slow and time consuming. I know there has to be an easier way. (I guess 3 images is max will send in separate forum question)
Any ideas?
Jeff
title renamed for clarity by @Viveka_CD
