Revit: Energy Analysis fails when Include Thermal Properties is checked.
Message 1 of 1
When running the Energy Simulation in Revit with Include Thermal Properties checked, the run fails.
It shows an error saying: 'The analysis couldn't be finished. Please check If you are connected to internet. If the analysis still fails, report the problem to the Autodesk support.'
I've read some things about making the walls thicker, but I didn't want to change the wall because I wanted to simulate an already existing building.
thank you for the help,
André F.
Replies (0)
