Revit energy analysis adiabatic wall
I have the following problem: W ant to run the energy analysis in Revit for a row house but I don´t know how to set adiabatic walls. Can someone help me?
All the best,
Hi
I have got the same problem.
It would be nice if somebody can help.
thank you
Has this question been addressed?  I'd like to look at one bay in a large office and I was wondering if it's possible to make the roof, 5 walls and the floor adiabatic.
Thank you
Is there simply no way to make some surfaces on a conceptual mass model adiabatic? I don't want to model the entire building, I want to model a representative section of the building (a single dorm room), in which only one surface (the south wall) is exposed to the outside. I want to model a single window on that south wall, and investigate the effects of changing the window shading, SHGC, U-value, and area. I want to compare the relative effects of changing the window options and changing the wall U-value. I want to model the relative effects of changing the infiltration rate. Revit, at this point, appears to be completely useless for all of these tasks. It's extremely disappointing.
