Revit don´t let me do enough zoom
15 REPLIES 15
Message 1 of 16
FRAN1972
3865 Views, 15 Replies
FRAN1972
Hie,
I'm trying to zoom in with the middle mouse button but it won't allow me. It allows me to do less and a little more but it locks away from the element.
Regards
Hie,
Regards
15 REPLIES 15
Message 2 of 16
Yien_Chao
in reply to: FRAN1972
Yien_Chao
hi
I think the problem here is the DWG. when you linked it, is there a popup message? normally, if there is something in the CAD too far away, your linked CAD will have inaccuracies and difficulty zooming.
hi
Message 4 of 16
FRAN1972
in reply to: Yien_Chao
FRAN1972
Thank you very much for your reply. I have checked the dwg file and there is nothing strange about it or anything far from the origin. I deleted the dwg link in revit but the problem remains.
Regards.
Regards.
Message 5 of 16
FRAN1972
in reply to: barthbradley
FRAN1972
Thanks a lot.
Unfortunately i can change the origins because they are fixed by the BIM Manager.
Regards.
Thanks a lot.
Regards.
Message 6 of 16
@FRAN1972 wrote:
Thanks a lot.
Regards.
So, the DWG IS far, far away from the Internal Origin?  If so, better inform the BIM Manager.  Let 'em know about Revit's Distance Limit.  Perhaps he isn't aware of it. In any case, it's an easy fix.  Just move the DWG closer to the IO. If it's Shared, then reconcile afterwards.
@FRAN1972 wrote:
Thanks a lot.
Regards.
Message 7 of 16
FRAN1972
FRAN1972
Hie,
It don´t like a problem of the origins.
Regards.
Hie,
Regards.
Message 8 of 16
@FRAN1972 wrote:
Hie,
Regards.
What do you mean?
@FRAN1972 wrote:
Hie,
Regards.
What do you mean?
Message 9 of 16
FRAN1972
FRAN1972
Hi,e
I mean that there isn´t much distance from origin point to the geometry.
Regards.
Hi,e
Regards.
Message 10 of 16
I was referring to the distance between the DWG and the Internal Origin of Revit.
Why don't you post your RVT (w/ DWG) here for us to test.
Message 11 of 16
FRAN1972
FRAN1972
Sorry, i can´t send the file to confidencial items.
I attach a image with the insertion point.
Regards.
Regards.
Message 12 of 16
Unfortunately, screenshot doesn't help.  Additionally, your issue may not even be related to the DWG location. That was only an educated guess. Another educated guess is that maybe a cookie crumb got stuck in the mouse wheel.  Only half kidding.  Bottom line is that this is a tough one to troubleshoot.  Could be anything.  We could be here for days or weeks just throwing out guesses.
Message 13 of 16
FRAN1972
FRAN1972
Indeed, thank you very much for your time and if I find the cause I will write it.
Regards.
Regards.
Message 14 of 16
michael.coviello
michael.coviello
Autodesk Support
Autodesk Support
@FRAN1972   Does the problem happen in any view?
If you try this in a copy of the model, does this help to identify the element?
  1. Open the view.
  2. Right click and select "zoom to fit", the view will go white, this is always an indication there are far away elements.
  3. Make a box Select on the white screen in different quadrants.  (not selecting your actual model that you want to keep)
  4. The elements will be selected, some of which are far from the origin.  The filter would show which elements are selected.
  5. Delete these.
  6. Zoom to fit again.
  7. Repeat until Zoom to Fit ONLY Shows your model zoomed completely filling the display canvas.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
  1. Open the view.
  5. Delete these.
Michael C
Message 15 of 16
alapaatias
alapaatias
Observer
Observer
Have you tried using a scope box? I've encountered the same problem and using a scope box helped.
Message 16 of 16
szecic
szecic
Hi, this is relate dto your crop border. In the photo that i share crop border is soo huge that you cannot even see the project. In this view it does not let you to zoom in after some point. You should make the crop borders smaller. That's why scope box also helps.
