@OTHNIELHO.19
You did not follow the tutorial 100% :)... you have to bare in mind that the guy who created such tutorial is not really genius and it did not come out spontaneously. He rehearsed it several times to make sure that it works when he records and casts. Otherwise he would look like a Boss. After all, Pattern Base Panels are designed and modeled to fit a specific conditions
- The specific Form
- And a defined pattern/GRID...it adapts to some extent but it is not meant to fit all conditions
That being said, I have just noticed your other post on how to revolve the form...Notice the pointy tip of that form you have, and go back to that tutorial and watch carefully the end of the spline. Such pointy and acute angles cause the panel either to deform or to cause an error forcing you to delete it => the source of the spikes at the top. To mitigate that you have 2 options:
- Kill the point bullet top by detaching the Spline from the axis of the revolve
- Reduce the Section of the Profile so that it works with those nasty slim pattern triangles at the top
For the Panel...I have nothing against the square shaped profile and/or modeling both frame and glass in one pattern based panel, but personally I would use
- a Triangular Profile.
- and I would nest 1 family for the Frame and another for the Panel (not 2in1)
