Revit Crash when I want to Export to DWG or after Export
azad.Nanva
Advisor Advisor
azad.Nanva
Can anyone explain this or someone from Autodesk?
(view in My Videos)
vitorbortoncello
Try exporting the view without being in that specific view; it might be a graphics card issue
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
PrathapSekar
Hi @azad.Nanva,
Is your software upto date?
have you come across the below link?
Crash-at-trying-to-export-a-Revit-file-to-DWG
Thanks.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
azad.Nanva
thanks to your answer and with thanks to Autodesk group, I found the problem,it is still takes too much time,but not crashing.so it solved with download the last version of :
RealDWG 2025.1.1 64-Bit Update”
