Revit Contour Lines
Revit Contour Lines
Revit Contour Lines
I am working on a complex site and trying to get my 1' or 2' contour lines to show up but they will not, even though I have every option in 'Visibility Graphics' turned on.
I attached some screenshots to show what I am looking at. The first is the site plan with only a few contours shown but not where I need them. The second is the surface edit map to show that I have drawn the contours, which I double checked and they are still accurate. The third is the AutoCAD base file that I used to reference the contour lines. My site plan is set to be 200'-0" above the surface plane so it is not cutting the contours I need off.
SteveKStafford
Have you reviewed the Site Settings dialog and made adjustments there yet? Look on the Massing & Site ribbon > Model Site panel > small arrow pointing down at 5 O'clock.
Steve Stafford
See below:
It doesn't look like there is any relief for miles and miles from the Project site.  Is this a Toposurface from CAD Import?  Did you import it in at the correct scale?
