Revit components
Revit components
preshybone
Revit components
preshybone
I have checked through the components available in my Revit 2024 and I am not satisfied with the range of components available. How can I add more components to increase my options?
ralphdenhaan
You can download and install the libraries from here: https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
syman2000
You can also check out these website to get more manufacturers content
https://www.bimobject.com/en-us
https://market.bimsmith.com/category/Lighting_revit?regionId=92
https://www.bimstore.co/
preshybone
Thank you very much. This information has been useful.
Another issue I face is, when I want to load family into a project, the default folder that opens isn't the one which contains the components. So, how do I change the path to another folder?
ralphdenhaan
