Revit Color Schemes - Recent Subtle "Improvements" (gentle gradients) - Not an Improvement
boyd_johnson
boyd_johnson
Found the following past post - with a Solution.  In my opinion, I do not see how a Solution to the stated problem was provided...The problem persists.  Autodesk said they will not be changing anything about the original post, i.e., removing the "Solution" Tag.
Revit 2022 Color Scheme - more distinct colors by default
RSomppi
@boyd_johnson wrote:
Autodesk said they will not respond.
Where did you see that?
boyd_johnson
Regarding the previous post (where I provided the link above), it has an "accepted solution." However, the "Solution" is NOT a soultion to the original post in the forum. I sent an email asking Autodesk to remove the "Solution Tag (green band)" because it was not a solution. Via email Autodesk said they would not be changing anything.
RSomppi
Solutions can be subjective and it is up to the OP to mark them as such. Autodesk takes little to no control over this.
