Revit Cloud Rendering and Redirect Issue
Every time I load revit and click on a project it redirects to http://autodesk.com/revit-enu and then I have to manually open the project again for it to open. Also, anytime I try and render in the cloud I have no options to select a view. I've tried reinstalling revit and a360 multiple times and still doesn't work. Any advice?
RDAOU
@Anonymous
The discription you provided doesn't say much
Which version of Revit are you using?
Are you using Revit 30 days trial?
Has the trial expired?
Did you try a CLEAN uninstall and reinstalled again?
Using revit 2016 student version. I believe it thinks it's not registered/activated and when I try and do that a box comes up and it's blank and stays blank. What's the best way to go about a clean uninstall?
RDAOU
@Anonymous
There is a link to Autodesk Knowledge Base in my signature for CLEAN Unistall... you can follow steps there.
When you get to the point where you cleaned up your PC do not proceed to download from the Website...Use Autodesk Virtual Agent a link can be found also in my signature below...see Youtube below for instructions how to download from VA
