Revit - Civil 3D collaboration
- Mute
- Permalink
- Report
Hi, I am still new to Revit (learning it just last few weeks, so I started with 2025 already). I have some basic knowledge in modelling. I am now trying to "connect" Civil 3D with Revit but I am stuck with trying to put Revit model in real world coordinates while following tutorials. It seems that there is no Shared Reference Point for Autodesk Revit extension available for 2025. I can see it is available for Revit 2024, but not for 2025. Is it maybe included in Revit 2025 already?
Maybe I am going the wrong way with this. Can someone please point me in the right direction, to up-to-date tutorial or anything else about this subject because all tutorials and help resources I have found mention adding that extension and using it prior to sharing surface from civil3D etc.
As I have said, maybe I am going the wrong way. I am still just exploring how I can use Revit in my Civil 3D workflow. Basically I would like to use data from Civil 3D inside Revit and the other way around. For example:
-model a culvert/bridge in Revit and use it as an object in Civil (if it is in any way possible: show it in profile view, section view etc...)
-make a railway platform in Civil 3D (corridor, extracted solid...whatever needed...), transfer it to Revit along with existing surface and continue working on that in Revit: adding ramps, stairs, poles, sheds etc... And then bringing it back again to C3D to show it in views...
I am still trying to find correct sources on that matter. So basically, I am asking is this even possible in Civil 3D-Revit collaboration and if it is, please point me into right direction.
Regards
