- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I went to set up a file this morning as central on our local network to create a shareable project, and have found it will only let us edit elements by checking out Workset 1 as an individual user. That then prohibits another user from working on that same file. We have been perpetually getting the error "You do not have permission to edit the element". If we leave the workset set to "no" in the "editable" column, nothing works. Typically, in the past we have been able to just "borrow" elements at the individual user level w/o having to own the worksets. We are in 2019, but downloaded 2020, and it seems to work the same in there, too.
What are we doing wrong?
