Revit Camera View export to autocad deformed
Hi
I'm trying to export some camera views, on sheets, to autocad, so that I can print without the background and overlay them on the rendering from revit in photoshop. I seem to get deformations in the cad file, the lines closer to the extremities of the camera view miss the lines in the rendering. Tried this a few times with different sheets, used both revit 2016 and 2017, locked the camera views, the problem persists. When overlaying the print from autocad on the rendering from revit, the lines towards the extremities of the image seem to have different vanishing points, in some places they fall in place, in some not, the way the geometry is deformed cannot be corrected by scaling the image in any way.
Please help
Why don't you print the perspective views with Hidden visual style directly from Revit?
I do, but they print on a white background. The dwg can be printed without the background. From what I read on this forum, you can not print from revit without a background, unfortunately.
You print the perspective view with Hidden visual style to a PDF.  Open the PDF in PhotoShop and it has no white background.  Overlay that onto your rendering as you normally do.
