Revit Blank screen
Revit Blank screen
Message 1 of 10
Revit Blank screen
Recently all my revit programs are showing blank screen on all my views. The elements are there and
when I print it all shows up.  Please need help on this..
Replies (9)
Message 2 of 10
Change the background to white and if you see things, change it back to black.
Message 3 of 10
Nope, done that. Originally it was white.
Message 4 of 10
Done that.  Originally I work on white background.  nothing on all the views.
Message 5 of 10
Disable/enable hardware acceleration. Update videocard driver. Repair Revit installation. In that order.
Message 6 of 10
cbcarch
In addition to what Toan suggested-
-Does this happen on all projects? Try starting a new project?
-Do all users have this? Did you reboot/restart your PC?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 7 of 10
Is this a post-rendering issue? I've had this happen before. But it isn't "stuck" per se. I can fix it pretty quickly  -- and without using a hammer or duct tape.
Message 8 of 10
Viveka_CD
Hi @Anonymous
Clear your temp folder, repair Revit, and reboot/ relaunch and let me know if it still persists.
Also, check your task manager - if you have Trend Micro - OfficeScan Virtual Endpoint Security Protection- that may be blocking the licensing process in the background and the program hangs resulting in a blank background.  Switching it off resolved the issue in some instances.
Message 9 of 10
i had the same problem, and after reading this thread tried some of the solutions.  i will add that im using a laptop, and the reboot computer option didn't work.  what worked for me was turning off the hardware acceleration, and leaving it off as i rebooted the program.
Message 10 of 10
LMartinsENG
Observer
Observer
this is actually the solution that worked for me as well, quick and easy 🙂
