revit awkward checkbox
Simon_Weel
Advisor Advisor
Simon_Weel
Some users are presented a weird checkbox in the Properties Panel:
Seems to be user-related since the checkboxes show up correct for a different user on the same pc. So I guess the problem can be solved by creating an new user profile, but before I do that, I would like to know if there's a more easy way to fix this?
Simon
chrisplyler
Wow. I've never seen that before.
What happens if you resize the palettes? What happens if you un-dock / re-dock the palettes? What happens if you close the palettes and then bring them back with the View > User Interface tool?
Simon_Weel
Weird checkboxes stay the same in any case...
Simon
Viveka_CD
Hi @Simon_Weel
Can you try the following and see if it helps resolve the issue?
Set OptimizedViewNavigation=0 in the revit.ini
dyan75QGE
@Viveka_CD
@Viveka_CD  I have a similar issue but it only occurs in the visibility graphics menu, all other check boxes are fine.
Can you please help with this issue if you can ?
I've got two versions of Revit installed 2020 and 2022. I've updated graphics drivers and all tried with and without hardware acceleration in the graphics / interface options.
kYLESAILSSC
I just had this problem, looked exactly the same as the photos posted. I tried everything(reinstall, change the revit.ini file, deleted config file) it ended up being on a custom display scale on my monitor.
