Revit architecture templet scale for 2017 version
I just installed Revit 2017 and I chose Architecture templet
and it should show up archtiecture scale form somthing like 1/4"=1'-0" in option but it doesn't show me architecture scale at all.
So, I downloaded 2015 Revit again, and it doesn't have any templet at all,
there is no option that I can choose from the begining page, when I  ran the Revit.
I need to use Architecture templet with architecture scale. What can I do?
Thank you.
Scales are setup on a view by view basis either in the Properties Window or in the lower left hand corner of the view.   There isn't a template strictly for a 1/4" plan unless you make one yourself.
thank you for answering!
Yes,I clicked in the lower left hand corner of the view and it only showed me 1:100 or 1:300 etc. it does not show me 1/4 or 1/8 etc.
How can make one myself?
What template did you start out with?   The Architecture template I have OOTB has scales at x"=X'-0" or X"=XXX'
You might have started with the default Metric template, which does show scales as X:XXX.  Be sure you select the default template under US Imperial.
