Revit Architecture - Rotating Project North doesn't work on some of my mass geometries
mehmet_emin_anarBH6RC
These masses are the ones that I do with In-place mass. Why they are isolated from this action?
This post has been edited due to: @lauri_barnhart added the product to the title to help more community members find this topic.
I tried to make in-place masses as a group and lock them to 2 surface (so they can move with those 2 surfaces that act like x,y) but after rotation they went invisible. Pls help me
heather_tracy
Hi @mehmet_emin_anarBH6RC,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Heather | Community Manager
I still need a proffessional solution
Sahay_R
This is a known issue.
Some suggestions -
Make sure the Disjoin checkbox is checked before rotating.
Use a rotated scope box
Link your model into another model, rotate, bind the link
Edit your In Place masses. Convert them into families.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Thank you very much
