I'm having an issue in a Revit family I'm working on. It's a basic Air Terminal, but I was hoping to get the a formula that would set the duct size, depending on the grill selected. For example, if the neck of the Air Terminal has a neck that is 7-5/8"sq, that it would roundup and default to giving me an 8" duct.
I've tried using the following parameters:
NeckWidth = 7-5/8"
DuctWidth = roundup(NeckWidth, 1) [ideally the formula would deliver an answer of 8"]
This delivers an error of inconsistent units.
I've looked around and haven't had any luck finding a post where a similar issue has been resolved. So I'm reaching out here to see if one of you can find my error.
Solved by barthbradley. Go to Solution.
Solved by L.Maas. Go to Solution.
Something like this
Louis
Please mention Revit version, especially when uploading Revit files.
Revit - Inconsistent Units and how to neutralize them.
Revit has three different rounding functions Round, Roundup and Rounddown.
But no it does not have the level rounding. Just multiply by 0.01, 0.1, 10, 100 etc, then round and then divide again to get similar results
Louis
