Revit and laser scanners
Message 1 of 8
Good morning,
I would like to ask some questions, I hope someone can help me:
  • How you can import and manage data from a laser scanner in Revit?
  • Is it better as a point cloud or mesh?
  • What are the recommended formats?
  • Are there any limits or specific plug-in?
Thank you very much!
Best regards,
Andrea Martín
Fundación CARTIF
Replies (7)
Message 2 of 8
sureshchotrani
There are actually no limitations as such, what format do you have of laser scan?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 3 of 8
Thank you Sureshchotrani.
I'm using a Leica scanner, whose format is *.ptx
Do you know if I can import it into Revit? Are there any limitations (number of points, etc)?
Andrea Martín
Fundación CARTIF
Message 4 of 8
sureshchotrani
You can open .ptx files in ReCap, then in ReCap save it as .pcg, which you can insert in Revit.
Message 5 of 8
Thank you for such useful information.
Andrea Martín
Fundación CARTIF
Message 6 of 8
Please, where can I find all the formats currently available for point cloud importing into Revit (see the second picture of your 05-18-2015 answer)?. In parallel, could we work there with triangle meshes, and, again, what formats?.
Andrea Martín
Fundación CARTIF
Message 7 of 8
sureshchotrani
Click here & here
Hope this helps, I am not aware of triangle mesh.
Message 8 of 8
KyleB_Autodesk
Andrea Martín
Fundación CARTIF
Andrea,
Revit's ability to handle large-scale meshes is nowhere near as efficient as what we do with Point Clouds, so we'd strongly recommend the ReCap route.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
