Revit And Enscape Compatibility
Message 1 of 11
I have just installed Enscape on my computer. It is NOT Working, it is only getting into the loading screen.
What do I have to do? Is there any issue or compatibility between Revit and Enscape? Why is this just keeping loading and loading, until I have to stop the process.?
Thanks for any help.
Replies (10)
Message 2 of 11
aRcHiTeCt.JM
… hi @Anonymous
… there is no known issue between the two
… as per your description
… I am certainly sure that the “issue” is with your pc
… enscape is a very easy and friendly app
… but surely, you’ll need a good video card
… as well as some good ram
… check these enscape minimum requirements
… you should clean up your pc
… delete all temp files
… turn off restore points
… if nothing works…. then … maybe reinstall both applications
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 11
ennujozlagam
try to update your graphics card driver to the latest, try to refer to this LINK and see if helps. thanks
Message 4 of 11
Also check with the Enscape people - it could be a licensing issue.
Message 5 of 11
Thank you, Yes, it is an old video card compatibility.
My computer is too old for running Enscape and even for Revit, but at least Revit is working.
I'll try to update the computer. What will be the best or in this case the most reasonable specs for it?
Thank you.
Message 6 of 11
Thank you, it is not updating the drivers. It is updating the computer and the video card.
Very old machine, but the worst part is that is only like four years old.
Thank you.
Message 7 of 11
Thank you. I don't think it is license issue. Is that it is not even open, but now I know that it is because of the video card.
Thank you.
Message 8 of 11
aRcHiTeCt.JM
Thank you.
… hi @Anonymous
… take a look at the specification for REVIT
system requirements for revit
… but also the specifications previously shown for enscape
… when buying your next pc
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 9 of 11
Thank you.
Message 10 of 11
pls is any version of enscape compactible with revit 2009
Message 11 of 11
i use revit 2009. is any version of Enscape compatible with it
