No, but a golf tee is a fairly well-defined shape with dimensions that are searchable online. You could make a Revolve that matches the shape.
@RLY_15 wrote:No, but a golf tee is a fairly well-defined shape with dimensions that are searchable online. You could make a Revolve that matches the shape.
Yep. It'd just be a single revolve. Good learning experience if you're not familiar.
You basically just draw half of the profile of the tee, and then draw the axis line down where the middle would be. The revolve tool takes that profile and wraps it all the way around where the axis line is.
