Revit 3D to 2D
Revit 3D to 2D
Message 1 of 12
Revit 3D to 2D
I have a recurrent problem in Revit which I can’t solve. I am wondering if you can transform 3D view into a 2D one. I am working at some custom made furniture models and I need to add axonometric views with dimensions on layouts.  I can make the 3D or Camera view but can’t add proper dimension on it.
I was an Archicad user until recently and I know you can do this very easily using the 3D Document function.
Also I find the fact that you cannot convert 3D model into 2D annoying, it is very necessary in detailing. May be there is a way and I couldn,t find it, please help.
Thank you,
Replies (11)
Message 2 of 12
J450NP13
What format do you need?  DWG or PDF?
You could just set your sheets up and then print to pdf.
Message 3 of 12
I want to transform the furniture 3D into linework in order to add dimensions and tags.
It is not helpful for me to export it into PDF format.
I think there is a way by exporting the Revit 3D into Dwg file and after that transforming it into 2D in Autocad.
But I don't know for sure if I can add proper dimensions in this way and also is quite time consuming.
Message 4 of 12
J450NP13
Yes you can add dimensions to it....as long as you modeled it to scale.
Message 5 of 12
EXPORT > CAD FORMATS > DWG
Do that once you have placed your annotated views on sheets and it is a fairly automated process.
Message 6 of 12
J450NP13
And if it isn't to scale you can always scale it in autocad.
Message 7 of 12
Yess, I have the 3D view and the drawing at the right scale, but unfortunately I can't add the proper dimensions.
I can add one or two but for the rest of them I can't properly snap the dimensions on the model, it is quite annoying.
Thank you anyway,
Message 8 of 12
constantin.stroescu
Maybe I do not understand your problem too well , but if you want to to dimension a 3D view as a 2D axonometric View , you can do it by locking the 3d View and then using Set Work Plane > Pick a Plane , create the possibility to use dimensions.......
https://knowledge.autodesk.com/community/screencast/04b6d276-76b5-4237-b184-af4265d17fd6
Constantin Stroescu
Message 9 of 12
Thank you, exactly my problem.
I am going to try it know, I think this is it :).
Message 10 of 12
J450NP13
You can export it out as a dwg and dimension it in autocad as well.
Message 11 of 12
Works perfectly fine! Thank you very much!
Message 12 of 12
constantin.stroescu
you are welcome!
Constantin Stroescu
