Revit 24- I can't edit model groups
t_weiland
t_weiland
I just started working with a model created by a third party vendor. This is a multi-family project so all the Residential Units have been made into model groups. There are some mistakes in the Units that I need to correct but when I select the model group and click the "Edit Group", Revit goes into group edit mode and I can edit the model group but the "save changes" check mark and "cancel changes" x are not available in the ribbon. Furthermore, the model becomes stuck in group edit mode and the only way I have found to get out is Undo.
ralphdenhaan
Check this article: In-group-edit-mode-Finish-and-Cancel-buttons-are-missing-from-Revit-ribbon
For now, you can use the Shortcuts to Finish Group.
Try using the following keyboard shortcuts for the "Edit Group" panel:
  • AP for adding elements
  • RG for removing elements.
  • AD attaching detail group.
  • FG Finish and save the group.
  • CG Cancel.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
handjonathan
Hi @t_weiland
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ralphdenhaan helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
t_weiland
Yes, the solution suggested worked.
handjonathan
Perfect @t_weiland Glad you got sorted.
Jonathan Hand
lward
Community Visitor
Community Visitor
Thank you.  Have been looking for an easy solution for ages.
