REVIT 2026 Won't export to IFC?
katsanosengineer
Message 1 of 15
katsanosengineer
Hello, lately I've been having some issues exporting a project to IFC format. I have both versions 2026 and 2024 downloaded, and have recently switched to 2026. When I exported IFC's from the 2024 version, I had 0 problems doing so, but now, the latest version is giving me issues. It shows this message, (image)
I have no idea what the message might refer to, and since I cannot save the project in an earlier version like you can do in AutoCAD, I'm completely at a loss.
What can I do?
Replies (14)
Message 2 of 15
nadiaVXVWZ
Community Visitor
Community Visitor
I have the same problem.. anyone knows the response for that?
Message 3 of 15
FG_RVT
Looks like a Windows issue no? Like you try to overwrite the file filename.ifc but that file already exists and you don't have write permissions for that file / directory. I'd try to save to a different directory.
Message 4 of 15
mari.shimode
Hi @katsanosengineer, how are you doing? Please reply if you still need assistance. If you have solved the issue, please click the Accept Solution button on a reply you have found useful so that others who have the same question can find the information easily. Thank you.
Mari Shimode
Message 5 of 15
eddieDJL7E
I am also having this issue. Cant get it to work at all.  All permissions etc are fine.
EDIT: I tried saving the IFC to the desktop and that worked. I was originally trying to save to a mapped network drive and that was failing with the above error. I know the permissions are correct in windows as i am able to open and edit all files within the folder i was trying to export the ifc to.
Message 6 of 15
MiWolff
Does your Export IFC window show a version number somewhere. If it does not, your exporter is the out of the box one. Try updating it to the latest version.
Message 7 of 15
thiruvengadam.vijayaraghavan
Hello @katsanosengineer, if you are saving on a network drive, could you please check if you can save IFC files to the local drive, for example, to C:\Autodesk?
Message 8 of 15
geraldDUN6M
Community Visitor
Community Visitor
Yes, it works for me as well, save in the desktop. thanks for this one.
Message 9 of 15
mari.shimode
Hi @katsanosengineer, I have marked replies from @eddieDJL7E and @thiruvengadam.vijayaraghavan as an accepted solution so others who have the same issue can find the information easily. Thank you for visiting the Autodesk Community.
Mari Shimode
Message 10 of 15
nummetu
Observer
Observer
Hi! That doesn’t fully solve the issue. We also need to be able to create IFC over the network, as was possible in previous Revit versions.
Message 11 of 15
ryzhov_roman
Observer
Observer
I'm experiencing a conflict between the built-in (pre-installed) IFC exporter and the recommended IFC exporter plugin in Revit 2026.
It is possible to simply disable the recommended IFC exporter through this RevitAddInsManager to resolve the overlap.
C:\Program Files\Autodesk\Revit 2026\AddInsManager\RevitAddInsManager.exe
Message 12 of 15
jason.larsenPF5AU
I have the same issue. What was the solution?
Message 13 of 15
jason.larsenPF5AU
I am the same, I need to save over network
Message 14 of 15
b_romaniuk
Community Visitor
Community Visitor
Hi there,
the issue was resolved after disabling one of the BIM IFC Importer plugins.
It appears that the two IFC importers were conflicting with each other, which caused the export error
Message 15 of 15
martin_schoenhoff
Community Visitor
Community Visitor
we have the same issue but these Plugins are not shown in the revit add-ins manager. Any suggestions?
