Revit 2026.2 System Browser not available
EliseMoss
EliseMoss
I went to View->User Interface and the System Browser is not listed. I tried F9 and nothing happens. Where did it go?
TIA,
HVAC-Novice
maybe un-check and re-check? un-check, then re-start revit, then check again? Play a bit with it and see if that helps.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
mari.shimode
Hi @EliseMoss, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
EliseMoss
It turns out that I had turned off the MEP tools in Options to clean up my ribbon. In order to see the Systems Browser, this needs to be enabled.
mari.shimode
Hi @EliseMoss, it's great you could solve it yourself. Thank you for sharing the solution with us too. I have marked your reply as an accepted solution so others who have the same issue can easily find it. Please visit us anytime if you encounter any other issues in the future.
Mari Shimode
